Steering wheel alignment
I just had springs/shocks/upper and lower shock mounts, and upper control arm bushing all replaced. I had a 4 wheel alignment also. The shop said the rest of the front end was pretty solid. That said, my STEERING wheel after the align is of, it sits off center to the left. Should I take it back and insist it also be oriented correctly? The lion in the middle of the wheel is not straight, its head is pointing to the left a little, enough to bother me. The car has 100k on it now.
Couple of points. First, the steering wheel and column must be centred to the straight ahead position of the road wheels otherwise the steering power assistance will be confused! Later XK8/Rs with DSC would also find that system affected to a greater or lesser extent dependent on the misalignment.
Second point. If you think about it, that 'lion' might just be a Jaguar?
FS[SouthWest]: Momo Wooden Steering Wheel
RobertTheBloke
09-24-2015 11:48 AM
1964Daimler
09-09-2015 11:28 AM
