Steering wheel alignment
And while they're at it, they'll make other front end adjustments and inspections.
Others may reply with more knowledge and expertise, but there's three or four reasons why this could have happened. Two most likely are :
1. Tracking was done without making sure steering wheel was centred.
2. Steering wheel has been removed and incorrectly replaced.
I'm not sure this would be a definitive test, but (on flat ground) drive forward so the front wheels are pointing exactly straight ahead (and presumably, steering wheel doesn't ??) Put in "P" and remove key. Does steering lock operate, or do you have to turn the steering wheel to get it to "kick in" ?
If so ...I think '1' is most likely, so get the tracking redone, but make sure that the mechanic has the steering wheel centred and uses the adjustments on the track rod ends to move the front wheels to the correct position.
If the steering lock operates with the steering wheel off-centre, most likely that the steering wheel has been removed and not put back properly. If that's the case, I would wonder why ?
Andy Cox (12-29-2016)
I had a 4 wheel alignment done, and needed to replace a tie rod. Steering and pulling was corrected.
Car has since handles beautifully
This is pretty typical alignment shop practice. If a Tie rod is frozen, they tell the owner he can pay $250 for a new tie rod or they can adjust around it. Someone selling the car is going to save the $250 and let the new owner worry about it.
Any more than 1 or 11 o'clock and they run out of threads on the good tie rod and don't give you an option.
I have had good luck with parallel strings and just basically eyeballing the alignment.
Very little is adjustable on the front. If you assume the back is good, a set of ramps, some wrenches and a straight road can the get the steering wheel perfect and the strings make sure the tow is close to spec.
Adjusting one tie rod side out and the other side in by the same number of turns will get you close. Fine tune from there.
![Icon Banana](https://www.jaguarforums.com/forum/images/smilies/icon_banana.gif)
Then drove it to my shop for an alignment.
Swapped inner and outer tie rods for $64, some parallel strings and and some wrench work and my $850 miata went down the road straight as an arrow.
Even though it too had a frozen tie rod and an offset steering wheel when I bought it, my XK8 never even made it to the alignment shop after I redid the Front/rear suspension. Camber - no adjustment, Caster - just some washers, easy, rear toe - just use the original setting, Front Toe - Parallel Strings and a couple trips up/down the street. That was about 8,000 miles ago and the no abnormal tire wear and the car goes right down the road.
Andy Cox (12-30-2016)
