Steering wheel audio control - '97 xk8
I just repaired a long standing cruise control problem that may relate. When you remove the audio control, open it to access the circuit board, then check continuity from the pins on the board to the pins of the clock spring plug. The wires make some very tight bends coming out of the switch pack, and in my case the ground wire circuit was open due to a damaged connection.
99xk8guy
06-05-2023 06:28 AM
