Steering Wheel Center Pad
XK8 Comfort,
I went with a simple inexpensive touch up paint pen on my steering wheel and centre air bag. eB%y link below.
https://www.ebay.co.uk/itm/JAGUAR-Le...72.m2749.l2649
Not 100% final look, as the original paint colour had changed over time, but good enough to mask my scratches and scuffs.
Johnken (09-26-2019)
Kent, yes I think you have hope.
1) I was surprised to find a lot of what looked like scratches and weathering turned out to be easily removed and restored using a Magic Eraser.
2) I can't tell but you may have scratches that need refinishing. I had to refinish my leather seats. At the recommendation of another from here, I purchased Magic Mend brand leather refinish. When you order it, you select make model year of your car, then they actually presented the Jaguar trim code list to choose from. I selected oatmeal and ordered.
The final color is sent as part of the order based on that selection. Kent I was stunned - they could not have matched the color more perfectly. I've used the bottle I bought several times since. Color in the bottle is still stable and spot on 3 yrs later.
My point is, you can purchase the paint from that company separately. After a good magic eraser cleaning, if you need a touch up give it a try.
2 things: 1) the color will dry to match perfectly but the color will gradually synch up over 24 to 36 hours even though the paint is dry in an hour or two.
2) I mentioned magic eraser, that's an expensive brand name. You can get the exact same thing from amazon for a fraction of the price. I just picked up a dozen for under $9. These things are great for any non polished surface cleaning.
John
John
Two suggestions, one after the other!
First, a Jaguar main dealer will be able to give you the colours if you tell them the VIN. I have recently been told mine by sng Barrett UK branch.
Second, proper leather paint, if necessary combined with leather filler, will give an excellent job, with full instructions on cleaning, preparation, application and finishing. It is also easy to use, and, as far as I can judge, as hardwearing as the original. I have used products from thefurnitureclinic here in the UK, and they can provide exact matches. I have no affiliation with them, and I certainly do praise their products.
XK8 Comfort (09-27-2019)
Kent, +1 with the suggestions to color match a sample. Sitting here in my living room my minds eye told me the steering wheel is same color as seat. Maybe I'm wrong, maybe different for different yrs.
I'm sure the vinyl is wrapped around and below the edges of the airbag cover. Super easy to unbolt, then just clip a sample to match.
Yes you could unbolt it with out disconnecting the battery, but just not even almost worth the risk IMO.
Put the steering wheel in 3 o'clock position.
Tilt wheel down and out
Leave key in ignition or wheel auto retracts
Unbolt bolt #1 now in 12 o'clock position on back of steering wheel
Start car put steering wheel in 9 o'clock
Re aim the tilt and telescoping for access to bolt #2.
Turn car off
Leave key in
Disconnect positive battery cable
Wait a minute or 2.
Unbolt bolt #2
Lift the airbag out of place while watching the wires routing for reassembly.
Frankly at this point you could safely unplug the airbag.
My opinion: be safe. Just like a gun - you never point it at someone or look down the barrel period.[even though you are 100% sure it's not loaded]. If I put the airbag aside while I work on the steering wheel, I put it/point it where it does no damage if it went off.
Like i said it is an easy job. Hope it helps let us know how you do.
John
Turn car off
Leave key in
Wait a minute or 2.
Unbolt bolt #2
John
