Steering Wheel Drop Down
Guest
Posts: n/a
On my XK8, each new day the steering wheel must be coaxed down by pressing the saved setting 3 or more times. Once a new day has been started the steering wheel automatically drops to it's last position for the rest of the day. Is there some setting that can be changed that will cause the steering wheel to always return to its last setting?
Thanks!![8D]
Thanks!![8D]
Received 2,194 Likes
RE: Steering Wheel Drop Down
YOU ARE AWARE YOU HAVE TO HOLD THE MEMORY POSITION 1 OR 2(WHATEVER YOURE SETUP ON) TILL IT STOPS MOVING ON XK'S..BUT IF YOUR TALKING ABOUT THE AUTO FEATURE FOR EASY ENTRY EXIT, THEN MOVE THE JOY STICK ON THE SIDE OF COLUMN FOR THE TILTUP AND DOWN QUICKLY TO CLEAN THE INTERNAL SWITCH CONTACTS, AND THAT SHOULD FIX IT FOR YOU. THEY JUST BUILD UP DIRT, CORROSION FROM LACK OF USE
Hi
My XKR does this if I have not used it for a while.
If what the other guy says does not work you may have a slight battery drain, or your battery may be on the way out, which would account for it working OK for the rest of the day once the battery has had a boost
99xk8guy
06-05-2023 06:28 AM
Richard_gib
09-12-2015 07:08 PM
