steering wheel problem
The only fix is a new motor assy., unless someone has found a source for a potentiometer these days.
Cheers,
0353 (10-02-2016)
That's exactly the problem I had and spent many hours trying a variety of solutions given by a number of members of this forum. None of them worked for me for any length of time so eventually I found my own answer as detailed here.
https://www.jaguarforums.com/forum/x...motor+solution
It's been in almost daily use for well over a year now and has been faultless in performance.
Same here, I performed this fix over a year ago, and the tilt work every single time. I commute to work most days, so it is hundreds of times by now. It has been tested in a wide range of temperatures, too, from 15 F to 100 F.
For completeness, there is another long thread talking about cleaning the worm gears of the tilt motor assembly. While some folks report success, it does not seem to be as permanent a solution as this one.
Best of luck, keep us posted.
astromorg (10-03-2016)
Anthony8858
09-05-2016 10:48 AM
