Steering wheel 'spline' shaft alignment 03 XKR
Hello all,
Would anyone happen to know if the steering wheel can be 'misaligned' by one 'tooth' on the spline shaft, and if so, would this cause what looks like a misalignment of the steering wheel when the key is removed and the steering wheel locks. When the steering wheel locks are 'engaged' after removing the key, should the embossed Jaguar icon in the center of the steering wheel, ears be misaligned slightly after jiggling the wheel to ensure the locks have engaged, or is this irrelevant that the cat face is wonky after the steering locks, lock? Thanks
It would appear that everything is oky doky then, as what you have described is exactly what I was concerned with; that it has to be slightly turned to the left for the locks to engage and appears off centered as a result.
