Steering Wheel Stereo Control
Old 07-25-2012, 05:42 PM
Hare's Avatar
Default Steering Wheel Stereo Control
Afternoon,
I have put a new audio system in my 2000 XK8 conv. Its works fine but I would like to add the steering wheel controls. The system that was removed was in Alpine Premium unit.
I have purchased a Axxess ASWC controller unit which will work in a 99 but it informs how to hook up to a 20 pin conn.
I just pulled out my new system enough and the is a 24 pin yellow conn and a two pin con. I believe the yellow conn would be for the phone and the other unit for the SWC.
If any assistance can be thrown my way it would be greatly appreciated.
Old 07-25-2012, 10:33 PM
WhiteXKR's Avatar
Received 2,988 Likes on 2,125 Posts
Check carefully, it should actually be a 26 pin yellow connector, not 24 pin.
You connect to pin#2, which is a red/white wire on a 2000 (not pink/yellow as in 1999).
Old 07-26-2012, 05:20 AM
Hare's Avatar
Thanks for the assistance, will recheck this morning.
Old 07-26-2012, 09:13 AM
Hare's Avatar
Yep, that did the trick. Big thanks for the info.
Old 07-26-2012, 03:19 PM
EZDriver's Avatar
Man you guys are good, WhiteXKR.
H20boy
07-23-2021 09:39 PM
rusty37
04-05-2020 07:40 PM
mbergen
10-23-2019 10:26 PM
PMKimpton
08-03-2019 08:22 PM
AL NZ
09-04-2015 08:39 PM
Quick Reply: Steering Wheel Stereo Control
