Sticking DSC push button....
On my 2005 XK8 CF ed,...... the DSC button can stick when pushed, but does not disable the DSC.... (must be done to smog the car in CA)... I used some computer duster spray (it gets real cold, when this happened before in winter it popped out when the car cooled off) to see if cold would free it and it did momentarily so that I could get the car smogged.... but there needs to be a better fix... any suggestions?
How do you remove the plastic button without damaging it so that the inside can be cleaned if needed..... probably something was spilled or sprayed in there by accident by the previous owner.........
Thanks All.... The row of buttons doesn't really come out very far from the surrounding fascia unfortunately........ I see it breaking when trying to pop it off.... I may try the contact cleaner. Normally you don't have to mess with the button... but like I said you have to turn it off when having the car smogged in CA
jimforrest (uk)
02-28-2019 06:42 PM
