stock radio head
Good day:
Upgrading speakers in standard audio setup 99 xk8 convertable. Doing the front first and putting component in. Read the threads and understand the wiring. I was looking for the power output of the standard radio head unit and also make and model. I believe its an alpine. Was wondering how much power so I know how far I can take the upgrade. Do not want to go with a power amp and keeping it as simple as possible
Howard
PS: Live in Newfoundland Canada and having the worst dampest coldest summer in years while the rest of north america bakes. At least I dont have to worry about the green shower as the top has not been down in awhile !!!!!!!!
Howard
You will find that the head unit is short on power if you only upgrade the speakers. I installed some infinity kappa's 2 ohm, and while they sounded cleaner, they actually couldn't perform to their best potential without aditional power.
I have no figures for the output of the head, but guess 25 watts at best.
While this is not a high power output, it is quite a good quality unit.
What i did was to feed a power amp from the rear speaker input cables, and return it to the front speakers via the unused sub wiring, which runs from the rear shelf to the centre console. Crossovers installed below the console, which gave outputs to the mid bass door speakers, and mid range in the dash. The amp, installed in the boot (trunk) also directly powers a sub fitted in the rear shelf position.
The rear speakers were removed as they add very little to a good set up.
Tks for the reply
Have convinced me to go aftermarket
Was reserching but the only thing that was giving me pause was the bezel around the radio. But that was a neat idea of cutting the old one. Easy plastic to cut ?????. It will give it the same texture and look. I think I will keep the steering wheel controls so I need a wired remote input on the back or the stereo head
Howard
Howard
Tks for the reply
Howard
Howard
Very easy to do, and I have to admit I am not a big fan of the XJ surround, it is definately better than nothing but you still get that big step at the bottom and I dont think it is any good if you have the later type head unit fitted I beleive from 2000 on as the main surround with all the other controls in is also a different shape.
I did not think twice about cutting up the original head unit it would of only gone in the bin anyway, but I must admit there some VERY optimistic people out trying to sell them for £100 a pop
