stolen car ??
#41
Well went out two hours later and tried to start car to go for a ride (79 degrees no wind, nice riding weather) after I had closed every up and locked it up, car will not start so uncover ECM and TCM unplug ECM unhook battery and resistance is still 120 ohms each way, hook car back up (approx. 15 min and car starts) so I shut it off and lock it up to try again later. unhooked battery first before unplugging ECM
#42
Well that was short lived! Back to the drawing board.
#43
#44
Problems remain, have had several "no start" conditions and have not been able to measure anything but 120 and 123 ohms in both directions from the ECM outward. Have been monitoring the fault indications on Autoenginuity ScanTool and it was showing interment can message faults at the instrument cluster so removed same and took it apart looking for problems that might be seen and cleaned the cable contacts in and out of the board and reinstalled unit back in car , so will see what happens next.
#45
I am not a big fan of throwing parts at a problem, but there are usually a few used XK8 instrument clusters under $100 on ebay. If you do get one, a unit from a 2000-2002 non-supercharged XK8 should be plug and play. Make sure it has the yellow connector on the right, and not two black connectors.
Wb5Tom (05-11-2013)
#47
#48
#49
Well put 75 miles on the baby today and stopped and started it 10 times with no trouble, but only time will tell ( watched can activity on Tm, Abs, and ICm and saw no errors today)
Wish to think all for the help, it sure made a difference as the instrument cluster was the last place I would have looked (it had the modified backing in the unit also)
#50
Wb5Tom (05-11-2013)
#51
#53
Well after a summer off in the motor home I came home and have used the car daily for past 3 weeks and not a trouble one, prior to extended trip ,tried going around and tightening all ground connections I could find and the ecm has not reported a theft in about over 4 weeks of driving. Fingers are crossed for a while yet.
#56
#57
#58
This is an old thread, but I want to second the comment above: I was a reader of this forum while shopping for a used XK8; without the keen knowledge of the members within, I likely would not have pulled the trigger. The extensive knowledge shared here gives one the confidence to take the Jaguar leap and drive the car of our dreams.
Many thanks to the helpful members of Jaguar Forums!
xjrguy (03-13-2016)
Nati
05-16-2020 08:30 AM
SingBlueSilver
08-27-2015 02:20 PM
Vector
US Lower Atlantic
08-26-2015 05:36 AM
