Storage without battery...OK?
motorcarman (11-03-2020)
Honestly, I have done this the last 10 years with my 00 XKR. No battery while stored. I've fixed too many motorcycles and cars that have had battery shens wreck stuff. I put the Interstate Megatron battery on two pieces of wood, connect the battery maintainer, and pop it back in when I need a battery in the car.
Sometimes as the car sits the fuel loses some of its more volatile components and it can become gummy which causes the fuel pump to fail but there are lots of mechanisms and play in order for that to happen and it’s not guaranteed to happen but it’s not guaranteed not to happen. it’s always recommended to have a full tank of fresh ethanol free gas and ensure you have a good fuel cap to prevent the evaporation of those components or water moisture from contaminating the fuel and that is why some people start their car periodically- so that they can run some fresh fuel through the lines to try to cut off any chances of bad gas causing problems.
The only other problem I would think you’d be concerned about is the loss of memory in the various programmed modules. I’ve read several posts about people who had their cars stored for several months but when they go to restart it it won’t start. Is it a fuel problem? Or is it a security system issue where it doesn’t recognize the key fob anymore? Or is it something else? I know that on my Jaguar there is a specific transportation relay that jaguar uses after they build a vehicle and it’s being shipped to a dealer which I believe is meant to supply a small amount of power to various circuits so that they retain their factory programmed parameters. One would think that Jaguar would only install such a system if they were aware of problems resulting from extended storage without the battery connected or they would’ve simply just disconnected the battery. But they didnt.
worrasf
11-03-2020 09:30 AM
