strange AC
Gus,
It is still hot in Florida and yesterday had a strange AC experience with my '99. The AC was blowing cold on the drivers side and hot on the passenger side regardless of the settings. I had
the outside air mix turned off. I waited for it to all blow cold but passenger side stayed warm to hot. Any clues?
Thanks!
LaRue
Thanks!
LaRue
larueb (09-07-2018)
larueb (09-07-2018)
Blend door may be the problem but if you have air out of the vent then it is most likely the system is low on refrigerant. The normal is for the driver side to get hot air and the passenger cold but that is not always the case. I would get the systems pressures checked especially if it has not been serviced in awhile.
michaelh (09-07-2018)
