Strange electrical problem RESOLVED
Well, my wife who has hijacked my 2001 coupe and drives it daily, reported to me today that she didn't think the heater was working and also the heated seat wouldn't turn on.
I took it for a drive and found that although the climate control appears to be functioning completely normally, there is indeed no heat coming from it, no matter what setting it is on.
I then looked at the heated seat switch and found that not only does the switch not light up, none of the switches in that row operate either, so two seat heaters, traction control, front and rear fog lights etc. The switch back lighting is functioning. Everything above and below this row of switches is functioning correctly.
Ideas gratefully received please, as if I don't sort this out quickly my wife is likely to give me a considerable amount of grief
Many thanks,
Andy
Many thanks,
Andy
Separately, there is an off chance the control system is confused. Check the display when you ask for external temp. If the number has no relation to the actual outside temp, then that sensor needs to be checked.
Have you performed basic debugging? Tried with recirc? Push the heat on max (HI)? Put the vent to face only? Check of the coolant level? Confirmed the fans are running?
In addition, there is a great built-in procedure for diagnostic of the climate control. You might want to start there if there are any codes.
The seat heater is part of the seat control module. If the seat can still be moved, then the module needs to be repaired. There are lots of posts about this, the repair involves fixing broken tracks on the edge of the control board. If the seat does not move, then check the fuses (1 per side, located in the "fascia" when you open the doors).
Best of luck, keep us posted.
Andy Cox (12-14-2016)
Thanks for that. I understand where you're coming from, but my main concern is that both these issues happened at the same time and it's not just the drivers side seat heater not working, nothing in that row of switches is working, i.e. fog lights front and rear, passenger seat heater and traction control.
I'm not big on coincidence, so I suspect there is a link between the lack of heat and the switches not working.
I did try all the settings on the climate control including max heat - HI- at face level, recirc and max cooling -LO-, but the link to the climate control errors is most helpful and I'll try that tomorrow and see what is says.
Thanks again
Andy
Thanks again
Andy
Take a look at fig 12.1 – 12.4. The seat heaters are controlled by the seat control module.
Link http://jagrepair.com/images/AutoRepa.../jagxk2001.pdf
As for the no heat you need to check the fuse for the heater pump. Is located in the engine compartment left side I think #15 10a.
Now the bulbs in the back of the control panel lighting it are switched with the car lights but the light indicating what you selected I believe comes from the module.
Update
OK, so I've established that fuse no. 3 in the Engine Compartment Fuse Box - Left Hand Side, i,e, just behind the ABS pump has blown and replacement fuses blow as soon as the ignition is turned on.
This fuse is 5A and is listed as 'Security sounder, headlamp levelling motors, headlamp levelling switch, ignition +ve, centre console switch pack, adaptive cruise control.'
My obvious interest is in the 'centre console switch pack' part of it. I haven't had time yet, but I'll start going through the wiring diagrams to try and figure where the short or high current is coming from.
Any ideas, as always, gratefully received.
Andy
Andy
Another bit of info I forgot to put in the last post, is that if I operate either heated seat switch, I can hear a relay latching under the relevant seat (presumably a micro relay in the control module), so something is working but the seat heater is not switching on.
Also, I have run a diagnostic on the climate control and it showed a code no. 14, which is listed as 'Water temperature input malfunction. Instrument cluster output. Refer PDU.
Not knowing if this is historic or not, I cleared the code and re started the engine a couple of times and it didn't re appear.
Andy
Andy
Received 2,380 Likes
The most likely culprit for fuse #3 is the security sounder, located behind the RHS headlamp somewhere. The internal NiCd batteries corrode and it starts to digest itself.
https://www.jaguarforums.com/forum/x...0/#post1543965
You can safely just unplug it.
HTH,
Mike
HTH,
Mike
Last edited by GGG; 12-19-2016 at 04:58 PM. Reason: Edited by GGG at michaelh's request
Andy Cox (12-16-2016)
If the security sounder batteries go bad, is there any indication when locking or unlocking the doors ? Has anybody ever replaced the batteries in one ? I'm curious because I've never heard of this before, and my car is 10 years old. I'm just wondering if this can be done proactively to avoid the carnage.
Lots of different problems here, and like many Jaguar Electrical Gremlins, may well boil down to one small issue.
As far as I am aware, there are two types of "security sounder" (located below the headlamp on the right hand side wing (fender). The "intelligent" ones have internal rechargeable NiCads which, after 15 or so years, start to self-destruct and can cause other problems. It is possible to renew them, but not a job for the faint-hearted as they are "potted" in a sort-of rubber compound which is not like normal silicon. These will work even if a thief manages to disconnect the main battery and are linked to tilt-sensors so you can't get the car on to a low-loader or tow-truck to steal it that way. The other type - fitted I think to US cars - is "passive" so has no internal batteries and much simpler internal circuitry.
Both types can be disconnected with no other knock-on effect. Worth a try, but I don't think that's the problem here.
Gus's wiring diagrams are your friend here - and a bit of patience. It should be possible to track down the fault or at least narrow it down to a specific circuit or component.
Thanks everyone. I do have all the wiring diagrams so will have a look through them to try and figure it out, but first I will have a go at disconnecting the sounder.
It makes sense that if it is corroding badly internally, then it is quite possible it may create a short in the circuit and take out the fuse.
Unfortunately, time is not on my side at the moment and I'm not going to get a chance to look at this now until Christmas, but I will update the thread to let you know how I get on.
Andy
Andy
Resolved
David, thank you, you saved me a considerable amount of time with that tip. I had no idea where it was and was looking under the air box.
Disconnected the sounder, fitted a new fuse and hey presto........Mrs C has a big smile on her face now everything is working again and the heater is doing it's thing.
I haven't had time to look at the wiring diagrams yet, but I can't see why that fuse affects interior heat supply?
Thanks to all who assisted.
Andy
Andy
Digital Will
03-06-2020 03:50 PM
97 Xk8 mayhem
10-08-2016 01:27 AM
equicor
10-03-2016 09:30 PM
FS[Western US]: Selling 2 nice Jags, 87 XJ6 & 98 XK8,SF, CA
Chibi
10-01-2016 11:30 AM
