Stuck front offside Abs Speed Sensor 2001 coupe.
Hi, have recently had the usual abs/ traction fault indications permanently on, 2001 Xk8 coupe (uk).
I have now managed to clear the fault by replacing the front nearside abs speed sensor with a used unit (Lja2266aa) and by cleaning the offside abs speed sensor in situ!
Unfortunately the offside front speed sensor appears to be stuck/melted in and I am concerned that if I apply to much pressure it will break! As I wish to clean it properly.
Has anyone successfully managed to remove a stuck/ melted abs speed sensor without damaging it for re-use, as it is not broken!
Any ideas/ tricks without a major dismantle.
Rob
Rob
Given that, you might consider just going with your cleaning the sensor in situ rather than possibly destroying it to get it out.
KarimPA
09-12-2015 08:15 AM
innzane
09-02-2015 10:08 AM
