Stuck in P
Guest
Posts: n/a
My 97 xk8 just got locked in park. In the owers manual in the *Road side problems* it says if you have the stick shift that there is a small screw right abuve and to the left that you can unscrew with your key. After taking out the screw put your key into the hole and turn left until gear shifts into reverse. Next turn the key to the right to pull key out of hole. Then simply put the gear into neutral and start. It'a as easy as that. I dont know how to fix it back to normal, if anyone knows please tell me, Thanks.
Marque
10-11-2015 05:59 PM
