Stuck in valet mode
Best Cars (06-25-2014)
It sounds like you have the valet key. Otherwise the regular black headed key would open the trunk or if in the ignition, you could push the trunk button on the dash. If you do only have the valet key, look at the tip. The part that projects at the end, about a quarter inch, is slightly fatter than the corresponding black key. That keeps it from going all the way into the trunk opener. Carefully file it down, reducing the diameter until it does go in and you're home free.
It is likely that the lock is siezed and the wires from the trunk button are broken so neither method of opening works. Try WD40 or better still locksmiths graphite to loosen the lock. It is possible to get access if all these methods fail, there are holes in the trunk behind the numberplate from which you can actuate the lock. Once open trace the wires to the lock button and replace.
It (sometimes!) helps to see what should be happening inside the latching setup when the key is turned. The Parts Catalogue diagram is about the clearest:
![Stuck in valet mode-xk8-luggage-compartment-lock.jpg](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/89289d1480973134t-stuck-valet-mode-xk8-luggage-compartment-lock.jpg)
1. opening with the remote or the lid button
the electric lock actuator (item 3) pulls the remote release cable (item 5) to release the latch (item 1).
2. opening with the key
using the black headed key in the lock barrel (item 4) pulls the cable (item 2) to release the latch
If the key turns easily both ways in the lock, it's likely that cable (item 2) is detached or broken.
Jzar
09-27-2015 02:55 PM
