Summer-only tire warning
On my way to work this morning in the 30 degree clear weather, the road was dry and I was getting on the interstate and on the ramp, the rear end of the XKR breaks away pretty good. I was probably pulling about .6 G and starting to get on the throttle and was not expecting that. I reeled it in but if I had been distracted, it could have been a trip through the weeds. The very sticky 20" Yokohama summer-only advan sport tires just let it go. Just a warning that summer only tires are just that! If it's freezing out, go easy! A 180 wear index tire can be very hard in the cold.
Kind of embarrassing too! Hope nobody noticed.
I took my XJR with 19" wheels and Summer High Perf tires to VA last year at Christmas. Let me tell you, never again. I had never had these type of tires on a car before so that's my only excuse.![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
Since then I have switched over to all season tires - year round. Even though I live in central Fla where Summer tires make sense, I do like to go North in the Winter from time to time and it's not worth the risk with Summer Hi Perf. tread compounds.
I live right on the south end of the Chesapeake Bay in Virginia where it meets the Atlantic and the water modifies the temps around here.....they change more slowly and are less cold in winter and cooler in summer. Our typical winter day temp is around 45-50F. It has been colder than normal the last couple weeks, highs around high 30's to low 40's.
Sounds like Europe is having a mini ice age!
One of my most unhappy tire adventures was the year I took my brand new 89 Honda Accord (500 miles) with factory performance tires on it to Vermont skiing. I ended up pushing the derned thing up a mountain to the Trapp Family Lodge where I was staying! On the way home through New Jersey, it was the black ice at night as the car became a roller skate! White Knuckle all the way. I learned if it doesn' say M+S on it, stay home in the winter! Guess I forgot.
It is a good practical thing to do from time to time. You need to know what your limitations are, in all conditions. Otherwise, you could loose it ...IN A BIG WAY. I don't know about you, but I have a drophead, and I have seen what these look like after a roll over....I get a sore neck just thinking about it.
Johnken
09-15-2015 05:46 PM
