Sunroof ?
Sunroof ?
Is a sunroof an option on an XK8? I have never seen one with a sunroof and there is no mention of any in literature etc. Take a look at this car now advertised on ebay. If you look close you will see a sunroof. I suspect an aftermarket unit. Has anyone ever done a sunroof install?
Jaguar : XK Jaguar : XK | eBay
Not the equivalent of the tilt and slide metal sunroof available for the Jaguar saloons. I had one of these in an XJ40 and it was very good.
The Jaguar ones are bulky and reduce headroom by at least an inch. Not a problem for most people in the saloons but likely to be so for many in the Coupe. A.f.a.i.k they have never offered it for the XK8 - probably for this reason.
Mark
I believe Webasto supplies many OE sun/moon roofs and has some for aftermarket installation. Not your typical tilt/pop DIY sunroofs, plan on pro install and a fair bag-o-$. In fact, if you have huge desires they can probably engineer and supply a retractable hard top for you. Plan on submitting a slighty larger bag-o-$$$.
