Is the Supercharger Pulley / Air Filter upgrade worth it?
Guest
Posts: n/a
Hello, I have a 2000 XKR coupe and I have been thinking about switching out my upper supercharger pulley with the Mina Gallery performance supercharger pulley.
http://www.minagallery.com/jagxp/Jag...c%20pulley.htm
Has anyone done this? I'm curious if it really makes a difference or not. The local Jaguar shop told me it would make a big difference.
I'm also considering switching the stock air filter with a performance intake system. Once again, has anyone done this? Is it just hype or do these things really increase performance?
I appreciate any insight any of you might have.
Guest
Posts: n/a
Hey Jman3566,
I own a 2000 xkr conv. an have been concidering the same upgrades or similar upgrades. I've searched the net and read as many articles as I could find. Some say that we can't change the upper SC pulley. One mentioned it being pressed on with a 20 ton press, just to stop tampering. I've found a nother article that had a link to "pullyboys", they sell and manufacture pulley's and pulley pullers. They say with knowing the stock size they can taylor make us a pulley and puller (175$)to the exact psi of boost we want. Also why not just change the lower crankshaft pulley to a larger one, it will do the same. The down side is our car's run pretty tweeked as is with 12psi of boost. Most I've read about talk of 7 to 9 maybe 11 psi of boost. And some say the Eaton mp112 has a week nose beering and to must boost will cause damage. I would LOVE an difinitive answer on all this from someone how has done it already or someone how really knows.
As far as the intake, I've used them on other car's and the most i got was a louder sucking noise with no noticeable HP increase.
Also in my opinon if we improve the ability of the car to breath we must do the same for the exhaul (exhaust).
These are all VERY EXPENSIVE upgrade and mod's, so I to would love a real answer.
Please let me know if you here one!!!!
[IMG]local://upfiles/3658/479DF7B53DFA49128E8A9B2849C8D98D.jpg[/IMG]
Received 2,190 Likes
The Eaton is already spinning at its maximum efficiency, hence also why most don't even think of using it for higher pressures that 11 or 12 psi. This doesn't mean you couldn't get more power by spinning it faster, but more that it will cost you more power to turn the Eaton which will generate more heat (and noise) and in the end will not give not much more top end power. Even worse, the engine will consume more fuel because of the inefficiency gets more pronounced, and also more stress on the engine for little gain.
If you would do a dyno and would make sure everything was cooled very well before the run (best time for good hp numbers is in cold climates times), you might get a nice number, but when you are just driving your car and the full system is heated up (especially if you spin the Eaton faster) your 0 - 120 mph (just an example, is legal in Germany) might not be any faster. This is noticeable if you would do several 0-60mph for instance full power runs (which will heat up the system), then you will notice that the top end power will get lower and lower.
What you do feel (pending on how much faster you spin the Eaton) is that you feel some extra power earlier on the power curve, which will give you the feeling it is much faster. So if the price is low and if that is all you look for, then maybe a consideration, but as the gains are relatively low for a heavy car the joy might be short-lived. All depends on where you want to go.
Which brings me to sensation, a better designed exhaust with a nicer tone will give you a bit more performance, but so much more sensation due to the noise. That could be imho the best bang for the buck to start with. Any potential future mod will also benefit fromthis (if you select the right exhaust). That in combination with an air filter packaged in such a way it gets cold air (so not the open cone filters you see under the hood!!!) will give imho a good effect.
My 2 cents,
Andre.
Hi,
I installed the Mina intake and exhaust on my '01 XK8 and it made a HUGE difference. More power and a much better sound. The OEM intake and exhaust on these cars is severely restricted and the Mina systems really made a difference. I own an '06 XKR now and I'm going to install the Mina system on it. I'd go with that before I did the pulley. BTW, I installed them myself. The Intake is easy and the exhaust wasn't too difficult if you have a little bit of mechanical ability a good jack and some tools. Good Luck!
Jon
Jon
aholbro1
08-05-2021 05:02 AM
Wes Steenrod
09-06-2015 06:52 PM
rachelstr
09-03-2015 12:59 PM
