Supercharger rad bleed hose
Hi guys,
Does anyone know how to disconnect the bleed/vent hose from the supercharger rad?
The workshop manual simply says disconnect it!
It has a sort of plastic shroud thing that twists so I thought it would be a twist and pull type scenario but it didn't easily come off and I don't want to force it.
I've broken enough nuts and bolts and brittle buts of plastic already. I could do with out replacing this hose too.
Hi guys,
Is that the tiny hose to the side of the supercharger? Could you show a picture of the hose? If it is one of those 5/16” hoses with no clamps, you can just pull them out gently.
giandanielxk8 (07-23-2020)
