My 1999 XKR (right hand drive) convertible project has hit another snag. after changing the primary & secondary chains, pulleys and tentioners along with a number of other parts the engine is running well but the supercharger is constantly whinging.
I know nothing about them so I'll fire a number of questions at you:
It sounds like bearings, can you just changed these and if so is there a video explaining it?
would I be better off rebuilding/servicing the charger?
Is buying a reconditioned one, cost allowing a better option?
The supercharger has an oil bath bearing in the front and a permanently lubed rear bearing. Th oil should be changed but there is no schedule. I would say at least every 50K miles. The thing in the supercharger that usually makes racket is the coupler in the snout.If you can get to that, you may find your problem.
I should have mentioned that the sound a bad coupler makes is rattling. The coupler is plastic and does wear out. To change it, you remove the snout and just replace it. There are some you tube videos of it. If it is rattling don't let it go too long or you will be rebuilding the supercharger.
My 2004 whined when I started driving it (noticable) and I changed the oil with the AC Delco stuff (don't know what was in it - it was full and didn't look bad) which made a huge difference in the sound. Change the oil first, then see. My 2˘
Hi Guys!
I go to the Ford Dealer about every 25,000 Miles and buy (2) Bottles of Supercharger Oil. They sell it as the Ford Cobra's Supercharger is also an Eaton....Several years ago I bought a Kit from eBay which has a Couple bottles of S/C Oil and a suction Bulb and such to suck the Oil out but if you watch the U-tube Movie above, you will see better how to do it! It's amazing how much this helps....It really quietens down.
Watch and Store the Movie!
OH! I forgot to tell you...The Oil stinks really bad!
Powerhouse UK sell a kit to do the oil change. They also do supercharger rebuilds for not much money and the pulley upgrade for more power. You can find them on ebay.
To change the oil I need to remove the cover using a 5mm-3/16th Allen key but its pretty close to being rounded off by the previous owner.
I cant get in there to hammer a slightly bigger Allen key in place so I was wondering if anyone has had the same problem or knows of a cleaver way to removed the cover?
in your situation I would just order a new fill cap and after it arrives then use whatever destructive means necessary to remove the already damaged one.
Take your time. I've had luck using a TORQs bit of the same or larger size when Allen's get ratty - and if push comes to shove give it a few taps to drive it down into the bottom of the fill bolt/cap. If you can't get an angle to tap on it,,, kinda use something to lever/ pry/or wedge it deeply into the bit hole
I spent a long time today gently trying to undo the plug but no luck, when the new plug arrives I'm going to use a cold chisel to knock it out but I have a couple of questions first:
To unscrew the new plug I do turn anticlockwise?
Once out I'll clean and wire brush the old teeth but do I need to grease the new plug before I put it in?
“……To unscrew the new plug I do turn anticlockwise?
Yes, unscrews normally, counterclockwise.
I would use some anti-seize on it. Be sure to use the exact size tool when installing, so history doesn’t repeat itself. It doesn’t need crazy torque put on it. Just a good sharp snug.
PS: I always check mine whenever the hood is open to be sure it didn’t fly away. OCD at its finest.
I'd be all kindah nervous... I'll be waiting, on the edge O my seat... Bestah luck!
Did you try jamming an oversized torx bit into it? The start skinny and widen as you go up the shaft of the bit. It might just catch before you have to break out the chisel...
