SuperSport indicates R performance package
I am confused about options for XKR coupes. Mine is a 2002 so last of the Mercedes transmissions, 18" wheels and regular brakes. The dealer is confused about what was/was not available for my car and if upgrades for handling can be provided
SuperSport?
R Performance Handling Package?
( tauter suspension tuning through uprated springs and antiroll bars and tighter steering )
I drove a 2005 coupe that had 20" wheels but I suspect the real improvement was the R Performance handling package.
If that wasn't available for the 2002 XKR, is it simpler to sell my 2002 XKR and get a 2005 XKR with that package instead of having mine modified?
Local tuner shops tell me they cannot find sway bars or anything else to tighten up the low speed handling...
SuperSport?
The performance package was available later in 2001 after the introduction of the Silverstone but it would be cheaper probably to get a later model with the additional package on it, most of he later models would have the upgraded brakes, suspension, and wheels, Jaguar was unloading inventory on the final run and was including these options on most every XKR.
You can pull a fuse that will affect the power steering, in effect, give it some more weight. I don't remember if it was fuse 10 or 12 from the fuse box in the dashboard next to the steering wheel. It's your cheapest option. Give it a try.
Edit: Just did a search on the forum for the thread about the fuse. I noticed it was you who informed us about this. Now I feel like an idiot.
Is the difference between the Supersport R or the performance package and normal really that big? I would've thought stuff like that goes unnoticeable, just like half of the stuff on a Porsche options list.
R Handling Pack consist of the following over a stock XKR
High performance Brembo brakes
18" or 20" inch alloy wheels
Jaguar advanced Computer Active Technology Suspension (CATS)
Revised electronic control unit settings and revised damper setting for taut,dynamic handling
Uprated springs and anti-roll bars for increased in stiffness
A re-tuned variable ratio, speed sensitive steering system, giving a very direct feel and pinpoint accuracy
Ride Height is lowered by 10MM, further improving cars stability and poise
Ken
RayR (02-06-2023)
i own an immaculate Jaguar XK8 Cabrio and I am looking to improve the steering feel to make it more precise.
My thoughts have been to do the following:
- replace the rack and pinion by the R Performance one;
- replace the electronic steering module for the R Performance one;
- replace my front and rear rear Anti Roll Bar with the R Performance ones.
What do you think?
I do not have CATS shocks but have installed Arden lowering springs which have worked wonders.
What do you think?
If you want the benefits of the "R" Performance Package, the easiest way to get it would be to trade for a Coupe with the "R" Package... .It would not be cost effective to buy and replace all the parts needed to build one. ....My XKR is an "R" and it handles well but what do I need all of that for? I'm not Racing the Car on Weekends nor do I cruise around at 90 or 100MPH...That's when you need the "R" Package! Other than that, it's kind of useless....
Billy Clyde in Houston
I guess, when the time comes, I’ll buy an Alfa 4C as a third car.
Precise, what does that mean exactly?
I don’t find that the XKR is imprecise so much as a slower ratio than you would expect from say, a 911. New steering rack bushes, tie rod ends and such to take the slop out of system. You can also try adjusting the castor shims, less castor generally speeds up the turn in and reduces that dead on center feeling.
If you have already refreshed the bushings I might suggest that option. My car was previously at max castor and when I rebuild the front coil over I moved one shim to the other side and the steering “feels” better. Generally speaking decreasing castor will improve responsiveness of the steering inputs right off of center.
If you want to increase the ratio of the steering that’s a whole different level of undertaking.
Hello again and thanks for your interesting replies and attention,
I have owned my 2001 model year XK8 CABRIO for 10 years now and each year looked to improve some aspect of the car as ongoing maintenance. What I have done:
- brakes upgraded to correct 4 pot Brembos; (used and refurbished to new)
- wheels to BBS’s 20” Detroits; (used excellent condition)
- replaced front seats with correct Ivory Recaros reupholstered in Connolly leather by a master upholsterer a few kms away. I did not replace other parts of the interior;
- replaced all FRONT suspension bushes (rubber) & ball joints & anti roll bar bushes & steering rack rubbers and ends;
- replaced cat back exhaust with ARDEN system;
- replaced springs with ARDEN 3cm lowering springs.
The handling, although non CATS & not an XKR, is lovely.
I feel the areas still needing attention are 2:
1) the shocks are standard 20 year olds which I am looking to change with sportier. As of today, I have only found possible standard Bilstein shocks B4 which I have not purchased. Any ideas instead of the B4s?
2) the standard rack seems vague and imprecise so I have just found a used R Performance rack & pinion for $ 200 and purchased a refurb kit for it, new bellows and will have it refurbed to new by my master mechanic os 20 years. I have also got a matching steering control module ($ 20) which will slightly stiffen steering. I believe this should make quite a difference. Any thoughts?
3) should I get the R Performance anti roll bars? $ 300 job here.
With all this done I should have pretty much put the R Pack on. Not sure why the R Pack was not available on the Cabrio.
The shocks will never be the CATS ones but I hope that with a sportier replacement ones and the lovely ARDEN springs this we keep being one hell of a car.
What do you guys think? Is there anything I have left out? Anything I should / could be doing differently?
