Suprising Discovery Using Engine Restorer
Please watch this video, no more rumors or games here.
I have re tested the compression and all of my cylinders are up more 11 psi each more than before.
I have seen an increase of 4-6 mpg city,instant start up and more power as well.
The nikasil liner is old garbage,they dont put the chemicals is fuel that they use to.
There's no evidence that this product prevents the problem from happening, nor do these cars exhibit any trend of premature wear anyway.
The following 2 users liked this post by plums:
Gus (03-11-2014),
Mr. Feathers (03-10-2014)
Jumpin' Jag Flash (03-12-2014)
Be careful, Restore is a viscosity increaser. If you are already running full oil pressure, the heavy oil may activate your overpressure bypass and put unfiltered oil through your bearings. Just a heads up on the downside of this stuff. Don't use it unless you have nothing to lose.
Does RESTORE increase the motor oil viscosity?
No, RESTORE does not change the viscosity of the motor oil.
Who is right?
I used Restore in my Rav4 for years and it made a world of difference, I should mention it had 300,000mi on it. I do not believe in Placebos nor do I recommend them! As for the product being used to prevent cylinder washing in Nikasil I would say it works from the few e-mails received relating to that application.
aode06 (03-11-2014)
#28
The same here, It made a world of difference after some mileage, no more cylinder wash and power has jumped up big time.This stuff will not effect anything, its thin , so no need to worry, its not thick honey oil lol, so the manufacturer website is correct, as I'm speaking to you as a guy that just put some in my engine, and the jaguar loves it.
The following 2 users liked this post by aode06:
Mr. Feathers (03-12-2014),
weisberg (03-11-2014)
#30
Mine is in the post, a 1Ltr can is recommended for a 4ltr engine according to the info. Cost £49 including postage. Worth a try as he's been in storage since back end of August 2013. I'll check pot pressure before and after when I do the oil change in a few weeks time and report back.
ArtyH
ArtyH
Superman001 (03-14-2014)
#32
Put mine in yesterday after an oil change, will test it out during the next few weeks and post. Due to bad weather did not have the chance to do a pot check. I bought mine for about £49 I think for a 1itr can. How much was yours and how much did you put in?
Think it takes a few miles over 500 to 1000 rings a bell.
#33
#35
There's no reason to notice any difference if you didn't have a problem to begin with. If your compression went up 10psi/cylinder it wouldn't matter. Brutal recommends it for cylinder wash and so far it's worked for me, but we'll see. Maybe on high milage/worn engines it would restore power.
#36
Without enumerating all of my experiences with the cars and trucks that I have owned over the last forty years, I can say that it is my experience that additives can have some benefit for engines that have had a lot of wear, or are gummed up, but are totally useless for an engine that has actual damage. As previously stated, there is no such thing as "miracle in a can".
Also, if the engine is in relatively good shape, there won't be any noticeable improvements.
There are some people who are "purists" who disdain adding any sort of additive to an engine. One of those was a gentleman who lived across the street from me when I was in my early twenties and he was the Chief Mechanic for Delta in the New Orleans airport. Any time he saw me working on my car (at that time, a 1968 Barracuda) he would come over to lend a hand. He disdained any use of any additive whatsoever. One time I had some leakage, and I don't still remember what it was, but I was putting some anti leak product into my car. He came over and told me that it was useless and that I should not do it. I asked him why not, and he said, "It will ruin the gasket." I said, "So what should I do?" He said, "Replace the gasket." I said, "Well, then what does it matter if this additive ruins it?" and he walked away. Of course, in retrospect, as he was a mechanic for jet engines on airplanes and I can see where he was coming from, as in his job they would surely replace any such gasket, rather than trying some sort of additive.
BTW, the additive fixed the leak.
#37
Yes Kevin D, I agree with most of what you say. I used to use an additive called " Greased Lightening " for the engine, and I would put it in every oil change, gave it to my friends and they loved it too, but it is almost impossible to by now and it changed its name a few years ago. So this time I am trying the Ametech Restore more as an insurance than anything else, as there is not a problem with the motor that I am aware of. While I do not expect to see any improvement in the performance, I do not expect it to deteriorate but to stay the way it is longer.
#38
I used to drive up to 2,000 or more miles a week and I have had three vehicles that I put over 230,000 miles on with no internal damage to the engine, but the transmissions and suspension were giving out or had given out, which prompted me to buy another vehicle.
#39
Your owners manual has a specific caution against supplemental additives.
#40
