Suspected vacuum leak advice needed
Hi,
I need a little advice on finding a suspected air leak. I have been finding my xkr 4.0 ltr idle was a little lumpy when put in neutral and sometimes when you pull away from standing start it felt very slow.
There is also a faint tick when accelerating.
So I plugged it into my laptop and looked for any error codes and I found none.
I then started the engine and monitor its vital stats for a min. revving it to 2500 rpm for a few seconds and I noticed that the fuel trims were way off at idle speed but then settled around 0 when revved.
Has anyone else experienced these symptoms?
Am I right in looking for a air leak around the intake and supercharger and what would be the best method for finding it?
Pete
Pete
Phantom (05-06-2017)
Phantom (05-08-2017)
This is good advice, also, if you have done any work to the engine, make sure vacuum lines around the throttle body are all connected.
Well I stripped the intake off and could not see any obvious wholes in it or melting. The only thing I could find was where the breather pipe joined the intake it was a bit wet so I degreased it and sealed it with hot melt glue for a temp fix.
I taped the rest of the connections and dip stick needs a new o ring.
I did a cold test and found the LT trims are now sat at 0 but the ST was still rich but I guess this is normal when the engine is cold I need to check when it is fully warm.
I will keep you updated.
Pete
Pete
well its just worn and dose not seal as well as it should to be honest as it looks original I wrapped it with duck tape for now a trip to the hardware store and 50p should fix it.
I will get it warm and remove the taped areas one by one till I find the offending seal.
I am not sure what you mean by an old buyers trick? can you elaborate?
Pete
Pete
Pete
Pete
Phantom (05-09-2017)
It is not being used as a permeant solution just looking for the leak which is tiny.
I am now leaning towards it being a faulty maf as the readings go crazy even when the car is not running under further investigation.
I might have to put it in to a dealer for a full diagnostic with the jlr ssd software.
I cleaned then changed my MAF. Made a big difference and its dead easy to change. Have you tried MAF cleaner? NOT carb cleaner.
For a bit of a guide you can take a look at what I did. Simply CLICK HERE
This is some before/after photos of the MAF on cleaning. Did look very different. click to see photos
Hope this helps.
Hope this helps.
Phantom (05-11-2017)
Also, you can clean the sensor. Use a dedicated spray (I use CRC air flow meter cleaner), not some random spray from the garage. Check the o-ring at the base of the sensor.
Last, consider just getting another sensor. In general, I hate throwing parts at a problem, but they are downright cheap these days (much less than any diagnostics fee).
Hope this helps.
Hope this helps.
Well after trying all the things I could think of to find a leak I have to conclude I don't have one.
I bit the bullet and had a second opinion after not finding any sensors or leaks causing the fueling issue.
They advised me that I have a one or more failing injectors which is causing the car to be contently trying to correct the fuel trims.
Dose this sound right? and where is the best place to send mine for testing/rebuild if possible.
Pete
Pete
I didn't lock onto the faint tick you reported in your first post until a few minutes ago. It may indicate a leak in the egr tube that runs from the right side exhaust manifold to the intake manifold. It's a thin wall steel bellows known to form cracks.
If you can find a replacement it's very expensive and others have reported being able to weld it, but that sounds very difficult.
