Suspension faulr warning
Is your car equipped with the active suspension? Also have you had time to get a scan done that would show what fault codes triggered that light? If it's the active suspension it can throw a code without having a blown fuse or having a readily apparent effect on the cars handling as there may be a problem that at the moment the cars is equipped to compensate but it's still an indication that something is going wrong and it won't fix itself.
It will only get worse and get possible a lot more expensive.
Give us some feedback.
