Suspension Fault
Suspension Fault
Replaced upper shock mounts yesterday and now have the suspension fault. I used an allen wrench in the shock rod to prevent turning while removing/re-installing the nuts, so I don't think I messed up the wiring in the shock. I have checked the two fuses also, no problems, has anyone else had this problem, if so is there a fix?? Thanks for the info if any.
I'm certainly nonexpert,,, but yours is a very very good idea/suggestion. Many times I have worked on my car (with the battery connected) and ended up with faults that would either clear in short time or clear with obd. These cars don't like to be messed with while there is power in their,,, systems..
Majik Lasers
06-02-2017 07:30 PM
