suspension fault
Hi
Im a newbie
haven't worked on a car for 20 odd years
so just starting to learn about engine management etc
Over the winter my jag started showing suspension fault and the engine light came on, so I plugged in a code reader my son got me and got the codes P0333, P0430, which is showing bank 2 high and bank 2 knock sensor, I have noticed a slight missfire at idle, I can't find anything on the suspension fault
also what side is bank 1, and 2 I am assuming bank 2 is right bank when facing the car
should have mentioned its a 2000 xkr 62K on the clock Cats? suspension rhd
can anyone throw some light on this its driving me nuts
thanks
Jim
Im a newbie
thanks
Jim
Bank 1 is the RIGHT side, sitting in the driver's seat, a more conventional way of describing left and right. Bank 2 obviously the other.
P0333 is a B bank knock sensor out of range. More likely an electrical connection than the unit. Engine compartment been wet lately?
P0430 is catalytic converter B bank (left from the driver's seat). List of problems starts with electrical connections and end with sensor itself.
Fix the P0333 first and the P0430 may go away.
driver safz
09-26-2015 06:01 AM
