Suspension fault after replacing front shocks
I have not darkened the door of Jaguar Cary (formerly Leith Jaguar) in years. They simply do not have the master techs who know our older vehicles and have the experience to work on them properly. Like most Jaguar dealerships these days, they are staffed and geared for the Tata-era vehicles. Jaguar Greensboro still has a couple of master techs with more than 30 years of experience (Nhao Haboon and Georgiy Koshelev) and on the rare occasions when I need a dealership's assistance, that is where I go. Nhao and Georgiy make it well worth the drive....
The best local Jaguar indie shop in our area is Flying Circus English Cars in Durham, owned by Toby Briggs. Toby is one of the kindest, most knowledgeable British car enthusiasts I have ever met. He has given me free advice over the phone many times during the past six or seven years and whenever I reach my DIY limit on a repair that stumps me on either of our Jaguars, I take them to him. His prices are very fair and he will take the time to explain to you exactly what he found and the various courses of action that you should consider....
Call him at (919) 596-4250. His customer service skills and diagnostic capabilities for our older Jaguars blow Jaguar Cary away....
baguafit (04-30-2018)
Well good news is the suspension fault is off. Bad news is I don't definitely have an explanation as to what happened.
Removed the right rear shock to find that both wires had been cut and the wires looked like someone put them into a drill and spun them really tight. Perhaps the wires broke but sure look like a clean cut on both. After repairing the wiring, the suspension fault is gone. I cannot read the diagnostic codes so not sure if the front shocks are still faulting but at least the car is not riding in default/firm mode and the fault warning is not appearing on the dash.
I've been mulling over how to explain this and am at a loss. Only thing that I could imagine is that the suspension fault did not come on with only 1 of 4 shocks showing open circuit, but when I disconnected front shocks that tripped the fault and DTC or module were never happy again until I closed circuits on all 4 shocks. Doesn't totally make sense because I did a hard reset after 3 of 4 shocks were closed circuit and still had the fault...so there must be more to this. I have no idea about the right rear wire twist and cut...I don't see how the shock piston could have rotated over time winding the wires but maybe that's a possibility.
I've very thankful for all the advice on this and wish the picture was clearer to help someone else down the road.
Hi DGR -- sorry didn't see your comment until now. Yes, the problem was the coil springs were spent which I understand is fairly common and will get worse in time. Contributing to bottoming out was the rubber bumpers had rotted and fallen out. I've heard some say to just replace those bumpers to reduce bottoming out but you have to remove the springs to install them so I opted to replace the springs and add new bumpers. I bought a pair of replacements from DCR (Jaguar XK8 and Jaguar XKR Parts and Accessories) that were copies of the originals at a much more reasonable price. BTW beware there is a difference between coupe and conv springs so make sure you specify. I have the coupe and ended up cutting 1-1/2 inches from the top and bottom runs of the springs which gave me a slightly aggressive ride height and no more bottoming out.
Well, I think I may have figured the suspension fault mystery. The fault reappeared a few days ago along with an Electrical Fault. Upon looking at the shock connections, a sparkle caught my eye in the well of the top shock which holds the 2 wires. I got a flash light and could see some debris so put a tiny magnetized screwdriver in there and pulled out some fine metal shavings -- not much but they were long enough to cause a short between those two wires with each other or grounding out. My hunch is this was the source of my wild goose chase. Maybe too early to say for sure but at least this is a plausible cause.
The following 3 users liked this post by baguafit:
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
#28
![](https://cimg3.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/img_1469_41af26cc1b30e754f6e958a513dcbcad210b3e1e.jpg)
I am very interested in the solution of this fault - I also got suspension fault after patching into two wrong wires - so I now ordered a new control unit as I suspect this is what causes my fault. Once I replaced it I give You an update, still waiting for it to arrive..
original in XKR
![](https://cimg0.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/750x863/img_1470_c278725fe8f79904802e80ffaaf8e12167984827.png)
used replacment module - all # match
#30
And finally resolution...I hope So after I had the wires repaired and ~5000 miles of hassle free driving, Suspension Fault reappeared and diagnostic AGAIN indicated open circuit in right rear shock wiring harness. Having a pretty good guess as to what was wrong I went to a 2nd mechanic who pulled the wheel out and found the wires had again broken but in another place (not where previously repaired). Thinking the 1st mechanic must have did something wrong I paid my $800 and had it repaired again. Another 5k miles and another fault and diagnostic indicating the SAME problem!!! Finally figured out the bushing in shock mount was so warn that the shock was rotating slightly with every bump in the road causing the wires to wind. Replaced the bushing and repaired the wiring and hope I never have to post on this again!
Hope this is helpful to someone out there.
The following 2 users liked this post by baguafit:
Dargam (01-09-2023),
Steve SOMERS (04-20-2022)
ehaglund
10-18-2012 11:29 AM
rocklandjag
06-11-2011 11:42 PM
mmolaik
09-21-2010 02:44 AM
steffenvh
01-10-2010 11:45 PM
