Sway Bar Bushing Replacement
I have finally gotten these busings installed on my '99 XJR. Given the response I would get on very rough worn freeway concrete, I suspected that my sway bar bushings were worn out... after changing them and inspecting the OEM models I removed they were not noticably worn. Outside of being dirty they looked great. I just took it out for it's first drive about 18 miles on my country back roads near my home. The steering is noticably stiffer (a side effect I didn't expect), faint clunking and transmission through the steering wheel has been noticably reduced. Given my suspension is the sport suspension, I appreciate the change that I have seen to this point.
I will provide an update when I put a few days behind the wheel over my normal freeway route where I encounter all the normal trouble spots. After looking at the end links, I'm thinking they need to be replaced as well. I'll look for that as my next project in a couple months before the rain and cold really set in!
I took a good look at mine yesterday, well as good as you can without removing them and they look good also, I felt around and they rubberand did not seem to crumble. I guess it is hit or miss. I will be curious if you think you made a substantial improvement. Cheap upgrade if you like them
How long did the process take.
It took me over an hour, but I'm nursing a very sore shoulder from a motorcycle accident! The upper bolts are hard to get at with the interferance of the hoses. I didn't take off the splash pan, and I think the instructions indicate that you should, so I probably slowed myself down a bit.
I think the OEM's were still worn, just because they looked good, that doesn't mean that the bar wasn't still moving too freely in them. Ultimately, I think that the poly bushings are performing well. I just made the same 18 mile trip and am still feeling the same improvement. Whether or not the poly's are better than the OEM, I think that is ultimately personal preference. I like the stiffer ride of the sport suspension so the poly isn't offensive but others may prefer the OEM's.
I'll report back after my commute tomorrow.
Jaguar XJ8/R/SPORT ( - 2003) Urethane Bushings
5 - Front Anti Roll Bar Mounting Bushing (33mm) PFF27-305-33 x21$45.99
Scott, these are for a XJR, I see that your signature shows you have the XK8, which is why we are in the XK8 / XKR forum :-) Here is a link to the ones for your model.
http://store.powerflexusa.com/jaguar-xk8-p1182.aspx
Jaguar XK8
PFF27-205-25 x2Powerflex Urethane Suspension Bushings$49.99
They come from Europe, I think they took a couple of weeks to get to me. I lost track of the time as I was caught up with a bunch of other things and I didn't care when they showed up.
Jaguar XK8
#32
The Polybush part number for rear anti-roll bar is PFR27-208-17
#35
#36
#38
Try this link Energy Suspension Sway Bar Bushings - JEGS
Or this link http://www.summitracing.com/search/D...R/?Ns=Rank|Asc
#39
Thanks for the links, i actually am talking bout the rubber grommet like bushings at the end conntion of the sway bar to the lower A-arm.
One bushing has a crack in it, dealer wanted quite a few bucks so i bought the oem parts for both sides.
Question of the day is it appears to be under tension and would rather not have it smack me in the face when I loosen bolt to slip new bushing in.
Is there a method that avoids this (ramp under wheels, jack up body on both sides, wheels on groujd, etc.).
Seems to be rather simple task for the money that was requested. Am i missing something?
Thanks again for the response, the busings are cool, I may upgrade.
-Steven
-Steven
#40
