System not ready code
Old 08-22-2016, 09:20 PM
daves_ale's Avatar
Default System not ready code
Hey guys, been awhile since I've been on the forum. A search brought me countless results so I'm hoping that those in the know can help me out:
About a year ago I came across the solution to the system not ready code and like a fool I forgot to bookmark it. If y'all could please point me in the direction of the right thread I'd really appreciate it.
Thank you for all your help
Old 08-23-2016, 04:33 AM
GGG is offline
Received 16,851 Likes on 12,186 Posts
Do you mean P1000: on-board diagnostic tests have not been completed?
Old 08-23-2016, 05:21 AM
daves_ale's Avatar
Yes, that is correct. I know it takes a series of driving at alternate speeds and such, but I could've sworn that someone posted here about a way to shorten the amount of time and driving to clear this.
Old 08-23-2016, 06:06 AM
avern1's Avatar
Received 1,319 Likes on 1,004 Posts
Give this sequence a try. Do you have a mechanic that can read the various systems for readiness and determine which one is giving the problem,
Try the sequence listed in the attachment and if it still doesn't set get it sscanned for the culprit.
File Type: pdf
daves_ale (08-23-2016)
Old 08-23-2016, 06:20 PM
daves_ale's Avatar
You guys are great, thank you!
Old 08-24-2016, 05:56 AM
jamdmyers's Avatar
Here's the link
https://www.jaguarforums.com/forum/x...pected-115863/
I recently fought a emissions not complete, ended up being the purge valve, this was a pain due to not passing NY inspection till resolved.
Old 08-24-2016, 12:43 PM
I lived on a hill and was never able to get that code to clear after adjusting my intake. I found that if I drove the car to the airport on a trip with the gas tank about 3/4ths full and then drove easily home that the system would clear on that drive (I'd do a full reset before leaving). I'm in Oregon now and they don't do smog checks which is an even better way to resolve this.
a6kmita
05-08-2016 11:59 PM
happilute
07-21-2007 11:41 AM
Boosted5cyl
07-12-2007 08:55 PM
sempaipaul
06-30-2007 06:49 AM
Quick Reply: System not ready code
