My experiments with wheelchair loading have resulted in my scratching my (otherwise spotless) paintwork. Would anyone with a clue recommend T-cut? Ive no idea.TIA
Voila
Voila
rub a drop of oil into the scratch, if it 'almost' disappears then using t cut or other similar will help lessen the obvious deep cut. I think it is too deep to be removed but you can lessen the appearance of it a bit. If it does almost go away after the oil, I would clean the oil out with some alcohol and then carefully fill the scratch with clear laquer then finally polish it flat and shiny.
good luck
wj
Unfortunately it's though the clearcoat, the base (colour) and down to the primer. No form of abrasive polishing is going to remove that. Two options for a DiY fix:
1. coloured wax polish (fills the scratch and makes it look a lot better but is only temporary
2. use a chip/scratch repair kit (e.g. Chipex - https://chipex.co.uk/products/chipex-lite ) will give a permanent repair but takes time and patience to get a good result
The other option is a professional repair by e.g. ChipsAway. Google paint chip repair + durham to find several local providers.
I've no fear of slow or fast hard work (as long as I can do it in bursts of no more than 3 hours) and as a point of principle more than anything I'd like to do it myself. I'm assuming I'll only need a small Chipex kit, they have them in my colour.I'll give one of them a go and keep the professionals in reserve.Thanks again. The people I got to know through owners clubs with my XJS encouraged me to try the XKR, although obviously 390BHP also played a part!
I would use dr color chip. Match my c300 iridium silver flawlessly to the point I couldn't find scraches or chips. Really easy to apply compared to anything else I've seen
