tail light blinking too fast
The following 2 users liked this post by WhiteXKR:
magnum454 (05-21-2014),
Sentinelist (05-23-2014)
Add a ground wire as described here: https://www.jaguarforums.com/forum/x...esolved-35083/
One of my lights went all wonky at one point- the top left and top right bulbs illuminated on brake, and I think the turn signal flashed the brake light. Really odd. Closest thing to an electrical issue I've had, but no more.
im guessing its the right tail light thats the culprit am wondering if you get a bulb failure message when you go in reverse? i took the connector apart at the rear rt taillight and found a bad pin thats causing the problem one of the pins keeps falling out.{believe it was the third from the right looking at the male end. i could jump the connector but will find a car thats parting out hopefully and salvage the connectors from it .
neruda
10-18-2015 01:19 PM
