Tail and Side Marker Lights not working.
Received 2,432 Likes
OK,
I suspect that there may be an issue with the lighting stalk. The wires occasionally break at the switch due to constant flexing.
Member Johnken has posted a pic of the switch:
https://www.jaguarforums.com/forum/x...2/#post1619272
The Electrical Guide gives Red with Yellow tracer as the wire colours for the sidelamps. As PB notes, a multimeter will help with diagnosis if it's not something immediately obvious. That wire should be grounded whenever the switch is at the 'side' or 'dip' position.
savhomer
22
06-06-2013 06:11 PM
coastaljag98
10-15-2012 10:19 PM
