telltale noises from failing chain tensioners?
Old 09-09-2009, 05:49 PM
qwakwak's Avatar
Location: Capitola, Calif - beach town - sunny side of Monterey Bay
Default telltale noises from failing chain tensioners?
I've read the threads on failing chain tensioners. Is there always a telltale warning noise when the tensioners are failing? One post likened the sound to an anchor chain being let out on startup. Is it worth the cost of having the tensioners inspected if there is no noise? ($650 quoted from an independent shop.) The engine runs quiet at startup and no problems are apparent.
I have a '98 XK8 with 54,000 miles.
Thanks for any advice
Mick
Old 09-09-2009, 06:15 PM
hlgeorge's Avatar
Just replace them and get it over with for sanity's sake. You will feel better and not have to worry about it any more.
Old 09-09-2009, 06:22 PM
test point's Avatar
Received 1,111 Likes on 932 Posts
You have the first generation tensioners. They will fail. The penalty for failing is the pistons will bend your valves. The positive side is that you get a new engine.
Chain rattle may announce the piston/valve situation, not just a warning.
My '02 had a split body at 46k miles. My '00 had the tensioners replaced twice under original warranty and Select Edition warranty.
Old 09-09-2009, 06:57 PM
qwakwak's Avatar
let me follow up with another question - is it necessary to replace all tensioners or just the secondary ones with the plastic body? bear with me, this is my first jag and I'm still in the learning mode.
thanks.
Old 09-09-2009, 08:31 PM
test point's Avatar
Let me stop and ask a question. Do you know that the tensioners have not been replaced? Many of the '97 - '98 cars have already had the work done.
It is the secondary tensioners that seem to fail most often probably because of the higher temperature of the heads verses the front of the engine.
Most owners only change the secondary ones.
Old 09-10-2009, 04:32 AM
GreenJewel's Avatar
If you're going to pay that amount of money to have it inspected you might as well have them replaced and be done with it.
I would have the water pump replaced it if has the plastic impeller and a good look at your cooling system hoses and thermostat & housing.
jeremys
09-30-2015 06:37 AM
ratgawd
09-16-2015 04:15 PM
Bowman
09-15-2015 06:54 AM
Dicque
09-12-2015 10:34 AM
davidladewig
09-11-2015 06:48 PM
Quick Reply: telltale noises from failing chain tensioners?
