Terraclean pros and cons?
My 2000 XKR is coming up to 80,000 miles. I have heard about this new engine decarbonising system that apparently is very effective at removing carbon from engines. I was wondering if any of you other chaps had used this service and could relate your experience. It sounds great but I am a little wary, many thanks. Dave.
Received 2,263 Likes
Boztron (08-25-2013)
I had my XKR done a year ago at Terraclean's UK HQ near Newcastle. I was initially so impressed that we started talks on my becoming the official distributor in France as part of my business. However, I gave the idea up when (a) fuel consumption dropped back to what it had been after a few weeks and (b) Terraclean failed to produce the certificate from Renault engineers which they had told me 'proved' the effectiveness of the treatment.
DevSpider (08-24-2013)
The smoke is from the Seafoam burning off (it's mostly light petroluem oil) not from carbon deposits.
I have better fuel economy as a side effect too. Bypass the sceptics.Nothing to lose.No damage can be caused.
Seafoam effectiveness can be judge by the color of the smoke it put out after the "smoke" treatment. If the smoke came out white then the internal is pretty clean. If the the smoke came out greyish or really black or dark color means alot of carbon build up that is being cleansed out. The darker the fumes the more built up it have in there that a second treatment might be beneficial until the fumes or smoke came out pretty white.
If the smoke came out white then probably won't feel much difference in terms of fuel economy improvement or throttle response. This means the engine internal is pretty much in tip top condition.
If the smoke came out greyish or dark that's mean the Seafoam is doing it's job.
From my past experience that few others agree back in my Ford days that some vehicle might need to have their spark plug replace after the Seafoam smoky treatment as it did foul and killed few spark plugs. Mainly those that are near at their end of life because few that I did with fairly newer plug survive. All those are with copper plug so I have no idea if these newer platinum or Iridium plug will survive or not because mine did in the Jaguar but it is also fairly new since I change it and the treatment was done afterwards.
I've done the smoky Seafoam treatment in multiple of my own car as well as friends and coworkers cars to conclude my own finding that I share with you all so please don't take it as a gospel but use it as my experience sharing.
Thanks.
Thanks.
Thanks.
Thanks.
Thanks everyone for the heads up. As Mikey says if it ain't broke don't fix it. The truth is I watched a British TV show which extolled this product for reducing emissions and generally giving your engine a de-coke and I thought why not. I haven't come across this Seafoam product here in the UK, it sounds interesting.
Oh! and Mr Frog, I tried contacting this company for info on a local company to carry out this process,they never got back to me! Not a good sign.Anyway Au revoir for now and cheers the rest of you guys. Dave.
I assume you are referring to Wheeler Dealers? That's how I became interested last year. I drove all the way up to Gateshead to meet them and was frankly shocked by their general attitude. It was like dealing with Geordie fruit sellers at the local market. I asked three or four times for the infamous Renault certificate and they never responded.
Wheeler Dealers it was. If this product is any good then it seems like a lost opportunity and the company who is acting as the distributor needs to get it's act together. I'm not sure if this a British product or where it originated from. From what you said it seems the results didn't last long anyway so didn't warrant the outlay. Cheers anyway.dave
Our History | Sea Foam Sales Company
Given it's composition:
50% light petroleum oil
30% naptha
20% rubbing alcohol
It can be seen why it might be effective with clogged fuel passages, but it can easily seen why there's no cleaners whatsoever or any magic miracle ingredients that would assist in carbon removal- not that modern engines have any that need removing.
For that matter, why spend $7 for a bottle of this stuff when it can be made at home for 50 cents?
As Devspider mentioned above, modern fuels carry more than enough cleaning additives to keep combustion chambers carbon free.
