Test unit
I have a 2001 xkr convertible. I have read many threads before I asked this. My question: What is a test unit that will read all the codes of my OBDII. Can someone recommend something current? Where to get one? Multiple options? My craftsman will read it, but not translate all codes.
Received 2,400 Likes
I'd beware of any reader's interpretation of DTCs other than Jaguar's proprietary diagnostic tools. If you have the codes, then refer to Jaguar's DTC lists:- I've attached the MY2001 P-code documentation.
https://www.jlridssddmongoose.com/
I have access to several good scan tools and none of them work for everything on these cars. A very old Autel MaxiDAS will read every module, but can't reset some codes, like ABS. A newer SnapOn will do most, but hangs up and crashes when reading the trans controller. A newer Autel won't go back to 2000. A new DrivePro will clear all codes but can't read the trans controller. It's all very frustrating. The electronics, while somewhat sophisticated are still very primitive, even compared to contemporaneous low-end BMWs.
I've been lucky and have been able to cripple by with these. If you can only get one, I'd suggest springing for the JLR Diagnostic kit.
![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
Mithrilweaver the Coventry Foundation placed a working WDS unit (loaded with IDS) in selective and strategic points in the US. In Texas the WDS is under the protection of the Jaguar Owners Association of North Texas. You can find their contacts on the JCNA web site. Warning--this unit is not portable so you must go to it. You also need some experience with it to use it. That said folks come down from Oklahoma and up from Houston to fix issues. Best wshes.
The following 5 users liked this post by Coventry Foundation:
michaelh (01-26-2024),
motorcarman (01-30-2024),
SCMike (01-26-2024),
Y2KJag (01-26-2024),
zray (01-27-2024)
If you plan a road trip East, let me know.
Bob
Wise County TX
