Thanks! Needing more help. Let's put all this things together!
Excellent, do you know the name of the thing that goes between the black plugs? I have one missing. Tks!
Tow hook (I suppose strictly, towing eye) - there are two different threads: early M20 is part # HJA4333AC, M16 is C2C37723. Not sure when the change happened. Some have used a bolt and welded on an eye. Do a search here on 'towing eye' for some ideas.
The plastic tool for removing the wheel nut caps is MNA6265BA. The key might be harder to source; you can try the dealer but he might want to sell you a complete set of nuts along with the new key.
I've attached a couple of pictures showing the trunk lamp assembly. It's in two parts, both which you appear to have.
Good job on the repair btw
A couple of inches of ball-point pen tube for 5 cents will do the same job unless you are worried about originality !!
