thermostat houseing
One should alway look in the DIY thread for proceedures/ links.
https://www.jaguarforums.com/forum/x...eak-help-3569/
graham11 (04-16-2016)
He is the way I did it Graham. I hope you are talking about a 4.0.https://www.jaguarforums.com/forum/x...ousing-119815/
Wayne
Wayne
This job is EASY. I did use crows feet type of wrench to get to the 4 bolts that hold the unit down to the top of the motor. When you are looking at this, on the FRONT of the black plenum behind the Tstat housing there is a metal plate, if you take that off it makes it much easier to get the back right bolt off of the housing. Be careful when taking the bolts out that one does not get away from you and rolls UNDER the plenum.
