Thermostat housing - details for replacement
Old 05-29-2013, 05:52 PM
Jerome_UK's Avatar
Default Thermostat housing - details for replacement
Hi all,
I am looking at the details of my very first DIY job on my lovely XK8: replacing the thermostat housing to upgrade with a full alloy one (and replacing the thermostat at the same time). That follows a small leak of coolant I noticed just a week ago (with a "low coolant" warning on the dash). It seems pretty clear (to me) that the seal at the bottom of the housing is the source of my troubles (white marks all around). The other possibility could be the water pump seal - the pump will be changed anyway if my problem persists or later in the summer otherwise.
Specific questions for the replacement of the thermostat housing:
1) Do I need to consider the replacement of the plastic outlet duct ? Has it a propensity to crack / break if disturbed ? It looks reasonably robust but plastic may age quite badly.
2) Spring clips: can I envisage to replace them by some more conventional hose clips ? I understand that a special tool is required for spring clips - which I don't have. Probably not a big deal but advices are welcome.
3) The access to the screws at the back seems to be a pain in the neck. Do I need to remove the inlet manifold for a better access ? I read that breaking the old plastic housing can do the trick - it sounds quite drastic !
Many thanks
Jerome
Old 05-29-2013, 06:53 PM
RJ237's Avatar
Received 2,819 Likes on 2,246 Posts
Hi Jerome, welcome to the forum.
1. I would replace the pipe.
2. No special tool needed. You can use pliers(English translation?) Do a search for procedure, or someone will chime in.
3. I broke mine up. Just keep track of the pieces. Removing the inlet maniflod is not a great idea.
Old 05-29-2013, 06:54 PM
test point's Avatar
Received 1,112 Likes on 933 Posts
Been there, done that!
I would suggest that you replace it. The plastic seems to 'rot'.
No special tool. Squeeze the connector together and using a sharp pointed tool lift the top side. No big deal.
The manifold should not be removed! Break the plastic housing with a pair of pliers. What, you want to keep the old housing?
You might still be faced with hard to reach 8mm bolt heads. Do a search on 'bent wrench' or 'ground socket' and you will see how it is done.
Old 05-29-2013, 06:57 PM
MCW739's Avatar
Hi Jerome,
This was one of the forst jobs I did on my car, reasonably straight forward. Removing the outlet tube improves access to the stat tower and allows for close inspection, mine was ok but I have read of them cracking so take a close look. Get new seals for replacement. The hose clips can be compressed with water punp pliers. Breaking the old tower to remove is one way but the new one has to be refitted unbroken so to remove the rearmost fixings for the tower I bought an 8mm combi-spanner and bent it at the ring end to form an 'L' shape (not quite 90deg). That allowed the ring to fit onto the bolt head, then a simple adjustable onto the open end of the spanner provided the turning force. Refit the new in the same way. Watch the wiring clips either side of the tower, they are a little tricky to unclip and easily broken.
Old 05-29-2013, 08:08 PM
Jag#4's Avatar
Gus (05-29-2013)
Old 05-29-2013, 09:41 PM
berlin1977's Avatar
You may want to check the upper and lower radiator hoses, mine had started to get the old bulge and would collapse when the engine was not running. After all you are going to have to drain the radiator.(My hoses were the original ones installed when new) I also used the standard screw type hose clamps. Jim
Old 05-29-2013, 09:44 PM
berlin1977's Avatar
Also a great time to flush the cooling system.
Old 05-30-2013, 04:13 AM
GGG is offline
Received 16,865 Likes on 12,186 Posts
You may also want to check the condition of the short ByPass Hose from the Thermostat Tower.
Almost every one I see is bloated like this:
A new one looks like this:
The spring clips are used for two reasons:
1. quick to assemble in production
2. give constant and pre-determined tension
If you replace the with Jubilee (worm drive) clips, be careful not to overtighten on the plastic components.
berlin1977 (05-30-2013)
Old 05-30-2013, 10:30 AM
Roadhogg's Avatar
Banned
Adjustable molies will do the hose clips (Halfords) and a 8mm crows foot spanner is supposed to be good for the rear housing bolts.
Or get a normal spanner and heat/bend it.
Attached Thumbnails Thermostat housing - details for replacement-img_0806.jpg   Thermostat housing - details for replacement-%24t2ec16zhjgeffm5rrt4nbro51kj2vw%7E%7E60_12.jpg
Old 05-30-2013, 11:34 AM
Jerome_UK's Avatar
Chaps, many thanks for your replies. Spot on, really ! The JagRepair website is just great, step by step with pictures, what else could I ask
I was not planning to replace the various radiator hoses but I will carefully double check their condition this WE.
Also I would rather flush the coolant once I have got access to a ramp later this summer. Let's start gradually !
Gus (05-30-2013)
Forcedair1
05-14-2023 03:28 PM
al_roethlisberger
09-11-2015 10:04 PM
obwoodie
09-03-2015 07:45 PM
KarimPA
09-03-2015 07:32 PM
d a
09-03-2015 02:34 AM
Quick Reply: Thermostat housing - details for replacement
