Thermostat housing and thermostat for 2005XK8
Has anyone noticed a rattling sound when they open up the box for a new complete thermostat housing and thermostat kit for the 4.2 L engine? I bought the complete kit from Welsh for my 2005 XK8 and before I got into the job I wanted to make sure I didn't have a defective part. Thanks much for your help.
I did my 03 this past fall, same as yours, I do not recall a rattling sound. Is it loud or soft? I am fairly certain there should be nothing moving around within the housing where the t-stat is located. Maybe someone can chime in.
Going to spend your money but since you have that apart may as well replace the Water Pump. That repair/wise preventative maint on this car is waaaaaay easy. I bought the orig type like what came off of it....
There are many that come with just a paper gasket. The orig comes with metal one and a oring. Here is my thread on my WP change with a few pics. It is really a easy job.
https://www.jaguarforums.com/forum/x...s-pics-131684/
jagxk82005seneca (01-10-2015)
I think I've determined the slight rattling sound is a check valve ball moving around in the housing. Great idea to replace water pump -- going to take your advice!
mikiep
12-20-2019 07:37 PM
