thermostat reverse?
If it fails to open the bypass won't open. This could cause problems during warm up as NO fluid is flowing to engine.
With a thermostat failure the by pass won't open because flow is holding it closed and you can overheat.
It needs to be in correctly and with the by pass in the proper orientation.
hawaiianjag
12-20-2020 05:01 PM
kamalislamof
12-22-2015 06:10 PM
