Thread Rotation Crankshaft Pulley?
Old 01-25-2018, 12:55 AM
JBD714's Avatar
Default Thread Rotation Crankshaft Pulley?
I'm in the process of removing the front timing cover and need to take off the Crankshaft pulley first. Is the directional rotation of the bolt the usual "lefty loosy" configuration? Second question: anything wrong with using an impact wrench for removal of the bolt?
Many thanks in advance!
Old 01-25-2018, 02:36 AM
phanc60844's Avatar
I use a 3ft breaker bar and a scaffold pole to shift it. If you are using an impact gun then it must be a pretty hefty piece of kit but personally i wouldnt us one incase the impacts cause brinelling on the big ends and journal bearings, just not worth it.
Old 01-25-2018, 03:56 AM
GGG is offline
Received 16,855 Likes on 12,186 Posts
Originally Posted by JBD714
I'm in the process of removing the front timing cover .....
Welcome to the forum JBD714,
I've merged your two identical threads asking this question.
Old 01-28-2018, 05:40 AM
johns55's Avatar
Yes, left to loosen. There isn't enough room to get an impact gun on the bolt, even with the fan pack removed.
Old 01-28-2018, 07:51 AM
Received 8,115 Likes on 4,898 Posts
NBCat (01-28-2018)
Old 01-28-2018, 08:36 AM
JimmyL's Avatar
Talking
... and a little elbow grease.
Old 01-28-2018, 08:51 AM
phanc60844's Avatar
Rope inserted through a spark plug hole worked for me.
As for the comment about the radiator being in the way, I took it out. A little more work but makes the whole job that much easier, for that matter I took the bumper off as well! but then it did need painting
