Throttle body butterfly position
Old 10-25-2015, 01:24 PM
Neil1664's Avatar
Default Throttle body butterfly position
Hi all, can anyone advise if the butterfly in the throttle body should be completely closed when there is no throttle applied? Noticed today that mine is slightly open and can push on it to close??
Thanks!
Old 10-25-2015, 02:37 PM
Gus's Avatar
Gus
Gus is offline
Received 2,213 Likes on 1,702 Posts
Slightly open is OK.
Gus
www.jagrepair.com
Thanks!
Neil1664 (10-25-2015)
Old 10-25-2015, 02:52 PM
Neil1664's Avatar
Thanks Gus, I just adjusted it so it was closed so will go and put it back as it was!
Old 10-25-2015, 05:38 PM
Gus's Avatar
Gus
Gus is offline
Did you adjust it for any other reason?
Gus
www.jagrepair.com
Old 10-25-2015, 06:11 PM
Neil1664's Avatar
Had a few vacuum leaks so had the inlet manifold off to sort them out. When returning to idle it's a little slow (sticks at 1000rpm before dropping for a couple of seconds) so when I noticed the butterfly open I thought that may be an issue..
Old 10-25-2015, 06:59 PM
Received 8,142 Likes on 4,912 Posts
If the ECM wants the throttle closed 'IT WILL CLOSE IT!!!'
If the key is on and your fingers are in the way, the ECM will NOT CARE!!!!!!!!!!!!!
bob gauff
Old 10-26-2015, 05:49 AM
Neil1664's Avatar
Ok thanks, so I guess it does not matter where it sits then.
Old 10-26-2015, 01:08 PM
Jag#4's Avatar
I assume you cleaned the throttle body while you were in there. Gunk buildup will cause sticking, especially stuff on the edges of the butterfly itself.
Old 10-26-2015, 03:13 PM
Neil1664's Avatar
Of course! It's now spotless
Old 10-26-2015, 06:20 PM
Gus's Avatar
Gus
Gus is offline
The throttle body is a fly by wire however, making adjustments that are not calibrated my come back and get you. Not knowing what you adjusted to make it close gives me reason for concern.
Clean is good!
Old 11-02-2015, 12:26 PM
Neil1664's Avatar
Just thought I'd post an update on this one.. The car will not idle if you set the valve in the closed position! So.. don't mess with the little adjustment bolt for the throttle stop on the throttle body!
Bill Swift
04-11-2018 04:08 AM
carl purchase
01-07-2016 03:54 AM
RLB828
10-27-2015 07:53 AM
garyp
10-23-2015 11:53 AM
casperxfs
10-20-2015 03:07 PM
Quick Reply: Throttle body butterfly position
