Throttle Body Eww...
Old 05-25-2013, 04:26 PM
JagTheRipper's Avatar
Forgot to say that these brushes were big enough so even if you dropped them into the TB they wouldn't go too far inside...
Old 05-25-2013, 05:19 PM
SeismicGuy's Avatar
Originally Posted by JagTheRipper
Ouch. I've done something similar. I once had a Nissan when I was still living in Finland. The car didn't have an engine block heater which is pretty much a must during the winter so I got one and though I'd save some money and install it myself. The procedure is very easy in theory. Remove one of the core plugs and install the heater in its place. Usually when you tap the plug with a screwdriver and a hammer to one side, it turns 90 degrees and you can pull it out. Well mine didn't turn. It felt like it was stuck (but in reality I managed to push it deeper in the hole). So one of my brilliant ideas was to drill a hole into the plug so I could use some sort of a hook to pull it out. I started drilling but it felt like the drill wasn't going anywhere. I tried harder and whoomp... It went through the plug, through the block, through the cylinder, through the piston... Needless to say how much I "saved" installing the heater myself
Sounds like we are in the same "Darwin" club!
Doug
Old 05-12-2021, 10:06 AM
Syb Drylst's Avatar
Default TB cleaning
Originally Posted by SeismicGuy
Okay doctor, for those that might not have a pair of long surgical forceps lying around, where can you get these (or something similar)?
Doug
Any auto shop would carry long needle nose pliers.
rominempire
28
10-08-2020 10:39 AM
RSpi
03-21-2016 12:02 PM
xjrjag
10-12-2015 03:16 PM
thedugger1
09-26-2015 10:27 PM
Quick Reply: Throttle Body Eww...
