Throttle cable adjustment
![](https://cimg8.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1500x2000/img_20200320_101923_bc6e4150fb3ad165d885dae3a64bfdcd4b4f4431.jpg)
I have read posts on cable adjustment but can't visualize it when I'm looking at mine. Can anyone advise? Am I missing parts? I don't see anything that will hold the cable under tension- no nuts or clamps etc. First time Jaguar owner so it's a bit of a learning curve.
If you compare the photo to the TSB you can see that the black plastic pieces on the metal bracket is the adjusting nut. You lift it straight up and if memory serves me correct you rotate it around the cable housing towards the cable end and then place it back in the bracket. Mine only took about two full turns and the slack was gone. The zip tie wraps around the metal bracket and the plastic sides. Very efficient for adjusting and restoring and keeping the bracket in place.
The following 2 users liked this post by avern1:
motorcarman (03-20-2020),
zray (03-21-2020)
I had the TB off on my 2000 xk8 and did the adjustment. The fitting that is in the metal brace off the TB is the adjustment. It should have a tie wrap clip that you need to remove. You then pull the fitting along with the cable out of the metal holder. To adjust the cable you spin the fitting on the cable housing to either tighten it or loosen it. When in place my cable is not tight but there is no slack either. Recmember to secure the fitting with a tie wrap.
The TSB was issued to address a possible problem with certain cars.
Besides, it looks like a salvage yard throttle installed on the engine. No telling if it was installed correctly or WHEN it was installed!!!!!!!!!
bob
avern1 (03-22-2020)
That sounds normal. Its the cold start system which runs rich in order not to stall and the RPMS are up. It drops off quickly and at operating termperature , around 200 degress the idle in my car is around 6OO RPM. My car is a 2000.
The 'zip-tie' was NOT the fix but an indication that the cable adjustment is correct from the factory or that the adjustment was performed!
bob
bob
The FIX is to twirl the adjuster to set the throttle.
The following 2 users liked this post by motorcarman:
avern1 (03-23-2020),
EnigmaX100R (03-23-2020)
john_cook12
06-20-2016 08:13 AM
