throttle cable adjustment
just put on a new throttlebody and now need to adjust the cable as its too slack. how do i do this? i used the search button but come up with the newer throttle body. my car is a 1999 model xk8. the one with 2 nuts on the cable sleeve end and attached to the throttle body. does any body have a pdf on this maintenance i would really appreiciate it thanks
Here's a thead with a lot of discussion about throttle cable adjustment, but the focus is getting out the slack that just naturally comes with time. You may have more than this method will accomodate.
https://www.jaguarforums.com/forum/s...throttle+cable
The best info on how to do it is Rev Sam's video at this link:
http://www.youtube.com/watch?v=AV8iF6SMjh8
His is a 2003, so yours might be a bit different.
Good luck -
Good luck -
FS[NorthWest]: XJ8 / XJR 3" Mina Gallery Intake Pipe only (For X308)
xjrjag
10-12-2015 03:16 PM
