Tighten Engine Bay / Shock Tower Brace?
How to you tighten the brace in the engine bay that connects the firewall to the shock tower? I have the cowl finisher nuts removed.
Only the windshield wiper arms prevent me from removing the cowl finisher; however, it is lose enough to can get my hand underneath and I do not feel any bolts holding the brace to the firewall.
Is the firewall end tightened from underneath the dash?
Received 2,190 Likes
GordoCatCar (11-12-2012)
I hope you got it. I had to get a small puller to get the wiper arms off the last time I did this (to get rid of the loud knock when rolling over bumps). Had some nice white corrosion holding them on to the splines like weldment. A little anti-seize and either me or someone else will be spared next time! I think you know this but maybe for others, if you haven't taken the cowl off before a little foam tape around the perimeter of the cowl may spare you future (different) noises. This stuff comes as standard issue on some of the later years but I think that was part of the "learning" from all of the '97 complaints. Jac
RoyLittle0
05-25-2023 02:38 AM
KarimPA
09-12-2015 08:15 AM
