!!Tilt!!
Before I go ripping through the thousands of pages of archives, I thought I would throw this out there. My steering wheel has suddenly stopped returning to the neutral position, after the car is parked. I can manually move it and return it to it's position, but damn if this car hasn't spoiled me to the point where I can no longer function, if it doesn't do it's own thing.
If this has anything to do with it, the windows don't drop and return now either. Once I have set them with the switch, they will work for 3 or 4 times, before I need to reset them again........Damn, I'm Lazy.......Thanks.........Mike
mrplow58 (11-26-2015)
Mike,
I've heard of countless examples of the wheel not telescoping out, or not tilting down but this might be the first one where the wheel doesn't retract and tilt up when you remove the key and the auto switch is on.
I'm with Graham about the battery, perhaps this is a new manifestation of low battery, congratulations
If not let's think what else it could be.
When you say manually move it, I assume you mean push it in - that's dangerous I dont want you to strip the plastic drive cable for this. Can you hear the motor running and clicking when you turn her off and take out the key? (hope not that's a sign of stripped) But then you describe this as a swinging problem so I'll assume the drive is not stripped.
I've already found out that motion (up down in out) via the switch on the steering wheel involves different components and/or circuits than that same motion via the memory buttons on the door. (FYI, my steering wheel switch rarely is able to provide movement, but the door memory buttons always work 100%). I'm pointing this out because you think they are more closely intertwined than they are.
With that background, let's think of your situation. Doesn't auto retract. (I'm betting more and more on the battery as I think about this)
1) As mentioned earlier, this action begins when you remove the key - any chance the little key flap is stuck "in" causing this? Gosh that would cause battery drain too.
2) The entire retract circuit is switched on the steering wheel. This is unlikely but could the switch be defective? On/Off would be easy enough to check, you can remove the switch pretty easily. Torx #10 as I recall to unscrew the two bolts bottom left and bottom right of the cowl under the dash board. Unplug the Valet switch very carefully it has come apart for many of us many times. If it does- no worry, you can press it together. Unplug the sensor in the upper right of the cowl (this action will cause your climate to beep a couple of times after reassembly and first ignition - just ignore it).
Then as I recall the steering wheel under cowl is 2 phillips head screws.
That gives you easy access to the switch and the connector to check continuity.
This should give you a good start. Let us know how you do.
John
John
![Icon Smash](https://www.jaguarforums.com/forum/images/smilies/icon_smash.gif)
The big prize goes to me, for the steering column.
![Icon Imnotworthy](https://www.jaguarforums.com/forum/images/smilies/icon_imnotworthy.gif)
Thanks jamdmyers, and Johnken......Evidently when my wife and son parked my car, the week before last, when I went into the mental hospital for my 5 year tune-up and detox,(4 days sweating, throwing up, freezing, 4 days getting new meds) someone must have accidently turned that switch.
After hours of checking circuits, and fuses....Mr. Big Time, stainless steel big *****, don't tell me what to do, bow before me peons, blow it out your ***, VW Porsche Audi Master Tech followed your advice, and turned the switch back to the correct position........Thanks to all of you.........Mike
![Icon Dunce](https://www.jaguarforums.com/forum/images/smilies/icon_dunce.gif)
FS[SouthEast]: 2005 Jaguar XKR Convertible Supercharged, $16,999.
divingmom
11-17-2015 10:29 AM
