Tilt still jams
Mine does this too - doesn't raise completely a/o drop into the memorized position. It can be "bumped" further along by repeatedly toggling the button though. Is this common to the problem as well?
I have to assume that the column's tilt action stops (jams) prematurely due to some sort of torque sensing issue. Has anyone identified a particular component, flaw or malfunction that would be responsible for this? (and be "the" guarranteed fix).
I notice that when the engine has been running the auto tilt works perfectly but not if the car has been standing for a while. I put in a new battery but it has made no difference. It's odd because when the engine is first started the system is still notchy. I can't figure out what's going on.
Bigvettefreak (12-06-2012)
WinterJag
16
10-09-2015 07:49 PM
3jagfamily
10-01-2015 01:49 AM
